Account
mhirmiz
Hi, I can't log into my account nor change the password. Also my service isn't working
So, whatever happened @mhirmiz; did you get services working and got access into your account?
Was this a brand new activation, that never worked yet?
Are you even a current customer with an activated sim card? If you have been in nonpay/suspended status for over 90 days, or ported your Public Mobile number to another provider, then you lost your Public Mobile account, phone number, and access to self serve/My Account.
@mhirmiz
When is your renewal date?
Did you keep up with your 30 day cycle payment? If not, your account will be suspended.
Refresh your browser then try again.
dust2dust
Are you not getting the email for the password change?
Assuming you're wishing to pay...do you have a valid credit card registered on the account? Do you remember your 4 digit account pin? You can the 611 system to make a payment. You can also buy vouchers and use 611 and NOT need a pin. You can also use real time payments in some stores.
Meow
Try using different browser. Try Incognito mode. Clear browser’s cache. Try force refresh.
If nothing works contact agent for assistance.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
