08-10-2022 02:43 PM
How can I get into my account if my email doesn't work any more
My Account
08-10-2022 03:32 PM - edited 08-10-2022 03:33 PM
@Beckz1 PM prefers you first try to submit a ticket via chatbot for customer assistance here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If unable to submit a ticket, then send a private message to CS_Agent using link provided or here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-10-2022 03:28 PM
08-10-2022 03:06 PM
08-10-2022 02:47 PM
The email address you used for your account is just login credentials. It can be a fake address. It can be expired. It can be deleted. It's just used for login. The problem is if you forget your password. But there's a texting option for that. If your service is suspended though then that won't work. Then you would need the support people to change your email address or reset your password.
