Account
R5
Please help.i lost my sim card and cannot remove the auto payment because i cannot log in into my account.its my friend who registered for me and he cant remember everything he put there.now i have a new sim card but im still being deducted monthly with my old account.
Hi @R5 I don't think you have it,  but if you have the 4 digits pin handy, you can disable Autopay using *611
but if you have new sim, you should get back to your current account and request Change SIM card.  There is no need to activate a new account
To get access back to your current account,
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. First type: "Forgot log in information"
  2. Then Click "Contact Us"
  3. Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
dust2dust
What you actually need is to regain access to your account. Then you can swap the sim card yourself keeping everything about your account. So contact the support people as given to get access to your account.
MrSpock
@R5 Hi you will need to  open a ticket   to speak to a customer service agent  they will help you  Click here or you can send private message to a CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
