Account
12-06-2019 12:43 PM - edited 01-05-2022 08:22 AM
12-06-2019 01:54 PM
You can elaborate on the problem. What is $33.00 for?
The account reset is tricky but you can do it yourself.
https://productioncommunity.publicmobile.ca/t5/Self-Serve/Password-Reset-Not-Working/m-p/407401
12-06-2019 01:19 PM
Best to contact a moderator with this issue by clicking question mark, bottom right, and follow instructions.
12-06-2019 12:47 PM
If you can't reset your password using this the forgot password https://selfserve.publicmobile.ca/forgot-password/ then submit a ticket to a moderator.
If you are having trouble with your services, the next step is to contact a moderator. Here is the link to create a ticket through SIMon:
https://www.publicmobile.ca/en/bc/get-help -> on the line "ask me something" write "moderator" -> then click on "account specific question" -> afterward click on "no, I want a human" -> finally you will see an answer "submit a ticket Click me!"
12-06-2019 12:46 PM - edited 12-06-2019 12:47 PM
@Dan8 wrote:$33.00 after 7 years why?
Can't reset my password or account? why?
Why ask why ? Click the ? in lower right side of page to start the process of moderator assistance. Type "password locked out" and then "Contact Moderators".
Can you please contact the moderators directly https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Then you can choose a better plan that is eligible for all the rewards
Which plan to you have and what is included?
