03-01-2023 08:06 PM
I forgot my public account login user name and password .
Pls advise how to recover?
03-01-2023 08:08 PM
If having issues about which email you signed up with (if you did register for a My Account), use the Forgot your password option to reset it, found here: https://myaccount.publicmobile.ca/en/forgot-password
If an email is received (check spam/junk folder) then the email is likely registered.
Have you ever created a My Account before? If not and you are a current customer (have been active within 90 days and have not ported out to another provider), you can submit a ticket here to: Create or forgot My Account email or password link
03-01-2023 08:07 PM
@jagjitsarao username is the email address.
First try to use the Reset Password link there on the login page (or direct link: https://myaccount.publicmobile.ca/en/forgot-password) enter any possible email addresses you could have used and see if it works
if not, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
