Account suspended
Options
11-04-2022 06:45 AM
Hello
as the site is still down I can’t login to my account to update my credit card information, if i buy a voucher to use with the *611 will I need many 4 digit pin to activate it
Labels:
Payment
1 REPLY 1
Options
11-04-2022 06:52 AM
As noted by @darlicious in the link posted below, you do not need your 4 digit pin to add the top up voucher to your account. That’s only required if you want to use 611 for topping up with a pre-registered credit card on file with PM.
