Account suspended
Rodica1
My credit card is working but I can’t process the pre-authorized payment and my account has been suspended can someone helps me.expecting very important calls from my family! What should I do!!!
8 REPLIES 8
AileenOK
I can make calls so that's good. I only know because of the sms they sent me. I can pay the way you suggested. Looks like a new plan in my cart so it just seems like a negative. Thank you for your help.
@AileenOK your account is now suspended without service?
if so, try my suggestion above to pay by using the option  Custom Amount and see if the payment goes through
AileenOK
Same thing happened to me. Instead of processing my autopay, PM suspended my account for non payment. Looks like there's an option to renew? But I had to join this group to send a complaint ticket.
Timer
@Rodica1
you can go to Shell Stations to purchase vouchers and add to your account by call 611
once connected press (1) then (1) again and enter the 12 digit PIN #,
Official list of retailers location sell vouchers:  https://www.publicmobile.ca/en/on/payment-voucher
@Rodica1
If your phone is still working and your renewal date is tomorrow, your account will show Suspended/Expired. This is a standard notice but it also indicates if you are on AutoPay or have sufficient funds just to ignore the message.
@Rodica1
Try to login to My Account, Payment page and make a manual payment.
But instead of using Amount Die, try to use Custom Amount and manually enter your plan amount that way and see if payment goes through.  Of so, logoff from My Account and reboot your phone
if still fails, you can also try to top yp via *611 with your 4 digits PIN (yiu can reset your PIN on My Account if you do not remember your PIN at this point)
Still fails? then open ticket with PM Support
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
JK8
@Rodica1
When is your renewal date? Are you on autopay? Are any of your services working?
Timer
@Rodica1
tried other browser and clear cache and cookies and use inPrivate mode,
or contact support team by CS_Agent
