Account number
Mperrin
Need my account number
8 REPLIES 8
@Mperrin
if you haven't activated an account yet but have a PM sim and are ready to activate, here's some easy to follow steps....
https://publicmobile.ca/en/bc/portal/activation
@Mperrin wrote:
I do not have an account to login. I just made this community account to get support
@Mperrin - check your email and search for 'public mobile'. When you activated the SIM card there should have been an activation email sent out to you. This email should have had your account number in the TO line of the email.
Have you ever created a My Account before? If not, you can submit a ticket here directly to: Create or forgot My Account email or password link
@Mperrin if you don't have an account login or unsure, please open ticket with PM support
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
Mperrin
Your not giving me a solution. It says that I need to contact support to get a public mobile myaccount
No account = no account number
You need to activate your account. Write down and save all passwords, pin numbers and security questions for future use.
Mperrin
hairbag1
@Mperrin
log in to your account, then Profile...you'll see Account Number on right side.
added...
@Mperrin “Log into self serve
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
