Account not working
k-factor
I can sign into my account but cannot view my "plan Details".
It is most likely due to issues trying to port a land line number.
Can you please help. Thanks.
Kelsey
15 REPLIES 15
@k-factor   Good to hear you have your number transferred and it's working for you.  Have you been able to access your account yet?
k-factor
Hey Dabr, the number came over and the phone is working now. My account is still jammed, but it should start working at some point. I will keep trying. Thanks a bunch for your help! can I give you points or something somehow?
k-factor
Thankyou. I will. I just spoke with Telus, and I have full clearance to port the number, they say they are waiting on Public Mobile to send the request. Lets hope it works this time.
@k-factor    Try sending a private message instead using the second link.
k-factor
tried already, I have no idea how to get it to generate one
@k-factor   Then you need customer support to take a look at your account.  Submit a ticket via chatbot here:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Second option if unable to submit a ticket, send a private message to CS_Agent here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
k-factor
I began this process on the 27th, so I think there is a bigger problem than just waiting.
k-factor
yes, my card has been billed. I tried to directly port the number, and it seems that I may have been wiser to get a temp number first. I have ported numbers before and didn't expect this much trouble. I started this process on the 27th, so its seems to be just not working.
@k-factor    It definitely seems like the website error that occurs every now and again, so you just need to be a little patient and keep retrying every hour or so.  However, it's always a good idea to clear your browser cache/cookies beforehand too.
benfatto
@k-factor  These two things are not related unless your account has not yet fully activated. Has your credit card been charged? Did you activate with a temporary number or try to transfer while activating?
k-factor
no luck. It keeps saying
Oh no!
It looks like something went wrong, but don’t panic.
Log out and then log back in again to continue. Or return to the Login Page"
Kelsey
Number porting is unrelated to plan details not showing on the Self Serve website  The issue with no plan being shown is long time website issue and occurs randomly.
k-factor
I attempted this, but it seems not to be working. it is like the site is jammed.
dabr
@k-factor   PM's website can be glitchy and some pages sometimes go missing for a short while but are available after a hour or so, so you can retry again later if clearing the cache/cookies/browser mentioned earlier doesn't help.
@k-factor
Landlines will take a few days to complete the porting.
Try clearing your cache & cookies and go incognito on your browser before login to your account.
