06-03-2026 04:51 PM
i recently changed my plan to $24 one. i tried to redem the code for extra data. is not working
06-03-2026 04:52 PM
Try again using browser with incognito mode
Or ask PM to help if you got the same error
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
