11-20-2021 12:23 PM - edited 01-06-2022 04:02 AM
11-20-2021 01:13 PM
@sonialorenz2014 wrote:I can’t because I forgot my security question
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
and them will reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck...
11-20-2021 12:40 PM
If you only RECENTLY activated and did so in-store, another possibility (though i don't believe this is your case) is perhaps your self-service account has never been created?
If so, click here to create a self-serve account
11-20-2021 12:40 PM
You need to contact a PM CS Agent by clicking on the SIMon chat button and type in Create a Ticket then follow the prompts.
You will need to supply your number, your security PIN, account number etc.
11-20-2021 12:38 PM
@sonialorenz2014 : On the chance that you're porting out, you can often also use the IMEI of the device the SIM is in. "Dial" #06#
11-20-2021 12:38 PM
@sonialorenz2014 wrote:can you please help me to get my account
If you're just trying to make a payment with on-file credit card...just dial 611, but you will need your pin.
You can get payment vouchers at Shell Gas stations then dial 611 to add them...you won't need a pin for that process.
11-20-2021 12:36 PM
Then you'll definitely need to contact the Customer Support Agents
11-20-2021 12:35 PM
11-20-2021 12:34 PM
@sonialorenz2014 wrote:I can’t log in it’s licked right now
Try this:
11-20-2021 12:32 PM - edited 11-20-2021 12:35 PM
@sonialorenz2014 try to look for the Welcome emai as suggested above. Or you will have to try Forgot Password link, enter the correct email and answer the security question.
if still fails, you will have to use Chabot to open ticket with PM to sort out.
follow this to get to the ticket open page quicker
https://publicmobile.ca/chatbot
11-20-2021 12:32 PM
If your account is locked, wait about an hour and try again using different browser or incognito mode.
If you still have issue logging in, try the Forgot password link to reset the password. You will need to answer security questions, though.
If you don't know the answer to the security questions, you can open a ticket with CSA to have it reset.
11-20-2021 12:29 PM - edited 11-20-2021 12:30 PM
Try a different web browser using incognito mode...or wait for an hour.
11-20-2021 12:29 PM
11-20-2021 12:28 PM - edited 11-20-2021 12:30 PM
As noted by @hairbag1, once you login to your Self Serve account and under your name, logout button. The account number is shown.
11-20-2021 12:27 PM
@sonialorenz2014 : If you still have the welcome email from here from when you activated then the account number is embedded in the To:. You might need to look at headers or source to see it.
11-20-2021 12:27 PM
@sonialorenz2014 simply login to Self Selve My Account and the account number is on the to right.
11-20-2021 12:25 PM
Log in to your account...you'll see your account number in top right side of page.
