Account no
Amitej
How to know the account no for phn no-xxxxxxxxxxxxxxxxxxxxxxxxx
No worries @Amitej
If you click on this link, it will open a private message to the Customer Service Agents at Public Mobile. Click on it and keep an eye on the top right corner for their reply.
Let us know how it goes.
Amitej
I do not have the email id with what I registered
Cheetah24
@Amitej: Edit your message to remove the phone number as that's not needed here and this is a public forum so exposing your phone number will get you into many scam calls over time. 🙂
@Amitej  You can find it in your account profile page tap the eye icon to view account number . If you can’t log in you will need to ask support for it
send  a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
add if you just need it to port number out , account  number is best but can still be done using the IMEI @Amitej  assuming you want account number to port out of PM
Chalupa_Batman
@Amitej please remove your phone number. this is a public forum
How to find my account number
Log into your account and go to Profile on the left hand side.
Then on your right hand side you’ll see this…
Click on the eye to see your account number.
Created by Chalupa Batman
