Account lockout
Skcudym1
My wife has her account locked now for several days and I can not get in even with new passwords. It just won't let us back in keeps says account locked try again in one hour. V
@Skcudym1
Just curious if your wife created a Eversafe ID if she is longtime member.
Click on Sign Up before login to her account.
If an ID was created then you need to contact a CS_Agent by private messaging between the hours of 9:00am to 10:00pm EST.
Skcudym1
No didn't work in the app either
will13am
@Skcudym1 , try ignoring that warning and login using the app, good chance it will work.
@Skcudym1  Since you tried changing password and have already waited the full hour please submit ticket with support to help k you regain access  . Use this direct link to support
send a  private message   To CS_Agents click
HI @Skcudym1
Maybe cache problem.  This issue usually resolvable if you use Incognito/Private/Secret mode on your browser to login again.  Please try
if that does not help, submit a ticket with CS agent:
