Account help
Joe55555
Asking to subscribe already have an account when I try to sign. In
Sansan
This means that your account is not attached to Eversafe ID.  Your can ask agent for help to attach so that you can sign in.
You can contact them at the link below.
@Joe55555
Your email address is not linked to EverSafe so contact a CS_Agent to link them together.
slusagm
you need PM to sort out the login issue
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
hi @Joe55555
you activate new plan, just an account setup issue, PM support agent can help
 you can submit  ticket by direct message:
