02-13-2026 04:20 PM
02-13-2026 04:25 PM
you need to pay the $5 if you want to change buy physical to esim
02-13-2026 04:22 PM
hi @Erum78
not free if you move from physical to esim
after you bought an esim, then getting esim replacement will be free as long as the last esim you got was over 15 days ago
to buy esim, download PM app on the phone you want to install eSIM, then login and go to Account page, choose Purchase sim card and select eSIM
