a month ago
Hi,
I changed my cellphone service from Fido to Public Mobile around 10 pm last night but my phone is still at Emergency Call Only status until now. How long should i still wait the message to change into Public SIM card, as my sim still the Fido one. Thanks in advance!
John
a month ago
Thanks for the info. I tried rebooting the phone and unfortunately still the same. So entered a ticket.
a month ago
Did you reboot your phone? Power the phone off then back on.
If that didn’t work then reset the Network setting on your phone.
If you are still having issues the contact a CS_Agent for help.
a month ago
Thanks a lot. I got your message and will call them now. Have a good one!
a month ago
hi @Ajzzh2026 check my message and call
a month ago
Yes. I received the message to confirm my transfer from Fido and said Yes. Fido also confirmed my approval to transfer. For now, i cannot receive any calls, nor message.
a month ago
hi @Ajzzh2026
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), use this link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
please use the same Community account login you are using now to login and submit ticket
