Account Issues
Rochelle04
i just registered and paid with the voucher..i got the confirmation email saying everrything is good.........when i log in with the email it says not verified...help pls
11 REPLIES 11
vcadieux
I don't think his is related as other people would also have the issue when porting...probably something went wrong during the registration.
A moderator will definitely be able to fix the issue.
@Rochelle04  no, you should still be able to get in your account
Rochelle04
do you think because i ported a number thats the issue?
Rochelle04
thank you
@Rochelle04 wrote:
@CS_Agent can i get help asappp pls
The moderator team can be reached via private message using this link.  Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
No, don't sign up again.  You should click on the envelope on the top right of the screen and write a message to the Moderator_Team team
Rochelle04
Rochelle04
hmmmm would i be able to sign up again or no?
You might have to message the moderator_team for help.  If you received the email it means they have the right email address unless where you create the username (Email)  you mispelled it
Rochelle04
yeah i did...the email says welcome shows me the plan...now let me try to log in with that eaxact email and nothing
GR
You did register online and set up the self serve account in the activation?
