Accidentally bought US data Refund?
666sarah666
I was trying to buy data just to add on for the rest of the day and I accidentally bought roaming but then got 3gb Canadian data thru my rewards . I am not in the USA.
can you please remove / refund ?
2 REPLIES 2
CSA_PM
Customer Support Agent
Hello @ 666sarah666,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Dunkman
@666sarah666
You will need Customer service agent to help.  Normally, recommend submitting a ticket, but the ticketing system is not working. I will try to escalate your case to CSA_PM.
