Accidentally Purchased Add-On to Wrong Account
schoi0708
Hi,
I have two accounts under my name (one for myself and another one for my mom).
I'm traveling to US right now, and I purchased the $20 US roaming add on.  The roaming service was not working, and I was panicking as I needed the data right away.  I purchased the second add-on to the second account thinking I may have added the service to the my mom's account at first.
Would it be possible to get a refund for the second purchase?
My first purchase was correct, but the roaming was not working due to some signal issue on my phone.
Thanks!
2 REPLIES 2
Acekiller
Hope they will credit you back!
will13am
Generally speaking, prepaid service has no refund option.  However, the moderator team is generally pretty reasonable.  I suggest you contact the moderator team, explain the situation and see if they will do something to remedy your situation.  The moderator team can be reached via private message using this link. Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
