About esim
Prerna2471
I have activated esim on another mobile and now want to change it to different mobile is there any way ? Or can i get a sim that i can get it from store ? @CS_Agent
TheSterlinger
If you got a SIM card then you would be able to.
TheSterlinger
If you want to switch between phones then you would need 2 eSIMs one for the first phone and the other for the second. Once an eSIM is registered to a phone you can’t register it to another phone.
Prerna2471
Yes
TheSterlinger
Are you using you want to use the same eSIM on another phone?
ESIMs are specific to that phone so you would need another eSIM for another phone. If you would prefer you can get a physical SIM card and use that you could get one on Amazon.
