About data
THP_23
  • Hi, someone can help me.
I have 1G data. But I can't send multimedia message  or receive pictures..
My cycle just renewed from 12 August 12 to  November 11.
Please..
2 REPLIES 2
DDM69
Check that your MMS is on.
dust2dust
1. Turn on cell data.
2. Check APN settings: (adding - assuming you have an Android. someone else can advise on iphone)
Name: whatever you want
APN: sp.mb.com
MMS proxy: mmscproxy.mobility.ca
MMS port: 8799
APN type: default,mms,dun
APN enable/disable: APN enabled - probably on anyway and greyed out
MVNO type: GID
MVNO value: 4D
Save, then select to use, then go in and out of airplane mode
