07-02-2020 11:44 PM - edited 01-05-2022 11:56 AM
Hello Community,
What is an APN? What are the defaults on an APN? When do we use them?
Eliza5
Phones
07-02-2020 11:53 PM - edited 07-02-2020 11:53 PM
@Anonymous 🤣 I had to I got the red bar first time to lol that you edited out of your post 😂
07-02-2020 11:51 PM
APN stands for access point name. They are settings used to help your phone access cellular data. Usually, when you put your SIM into your phone it will detect APNs. If you run into data problems you should go into your phone's settings and reset them to the defaults.
07-02-2020 11:51 PM - edited 07-02-2020 11:52 PM
nvm
Jb456 edited after the fact...cheater 🙂
07-02-2020 11:49 PM - edited 07-02-2020 11:50 PM
@Eliza5 wrote:Hello Community,
APN settings are needed to be able to use cellular data. Many phones have these already pre-configured.
07-02-2020 11:48 PM - edited 07-02-2020 11:49 PM
APN settings are for data (internet browsing) and MMS picture text messages.
Mine are this.
Save reboot phone and see if it works.
If not.
Try the below.
The Access Point Name (APN) defines the network path for all cellular-data connectivity. Some carriers require you to enter your APN settings to set up your cellular service. ... If you can't modify your APN settings, contact your carrier.
