07-10-2018 12:04 PM - edited 01-04-2022 06:25 PM
Hi all. I posted this question already in one of the other forums but thought I'd repost for greater exposure here (apologies if this is improper). I recently bought a nokia 3310 3g from the states. It's a single sim running on 850 and 1900 freq. and should work fine. voice and text are great. but i can't figure out how to configure the apn for data and mms. the canadian apn config site lists the data only for the intl version, not the us. i have a screen like this for access points:
Name:
Username:
Password:
Access point:
Gateway:
Port:
Set home page:
DNS address:
Network type:
IP type:
Found this on the AT&T site but don't know the pm equivalents: Name:NXTGENPHONE
Username:
Password:
Access point:NXTGENPHONE
Gateway: proxy.mobile.att.net
Port:80
Set home page:http://mmsc.mobile.att.net
DNS address:172.26.39.1
Network type:HTTP
IP type:IPv4
Any help is MUCH appreciated
Joining Public
07-10-2018 04:21 PM
finally got er done!
Settings:
Data:
Username:
Password:
Access point: sp.mb.com
Gateway:
Port: 0
Set home page:
DNS address:
Network type: http
IP type: ipv4
MMS:
Name: Public Mobile MMS
Username:
Password:
Gateway:
Port: 80
Set home page: http://aliasredirect.cnet/broxy/mb/mmsc
DNS address: 74.49.0.18
Network type: http
IP type: ip4v
THANKS!!!!!!!
07-10-2018 01:44 PM
thanks! some trial and error needed as the fields aren't exactly the same but i have faith we'll get there in the end!
07-10-2018 01:31 PM
Great! For MMS, just add the rest of the settings:
https://apn-canada.gishan.net/en/apn/public-mobile/nokia-3310-3g
07-10-2018 01:28 PM
@MacMe I did. In fact I think with some tinkering I've got data to work. Just working on MMS now.
07-10-2018 01:25 PM
If voice and text with, the phone if definitely compatible, at least on 3G. APN settings is needed for data only. Refer to this knowledge base post for apn setup.
07-10-2018 01:24 PM
For the data, did you try setting the Access Point Name to sp.mb.com?
07-10-2018 12:21 PM
@ShawnC13 it is. However, the single sim variant listed in the apn_canada site seems to be the international version as it gives different specs for the frequencies than mine. the us version operates on the same frequencies shown in the dual sim version on the site.
07-10-2018 12:18 PM
@thegreatswalmi wrote:Hi all. I posted this question already in one of the other forums but thought I'd repost for greater exposure here (apologies if this is improper). I recently bought a nokia 3310 3g from the states. It's a single sim running on 850 and 1900 freq. and should work fine. voice and text are great. but i can't figure out how to configure the apn for data and mms. the canadian apn config site lists the data only for the intl version, not the us. i have a screen like this for access points:
Name:
Username:
Password:
Access point:
Gateway:
Port:
Set home page:
DNS address:
Network type:
IP type:
Username:
Password:
Port:80
Network type:HTTP
IP type:IPv4
Is your phone the simgle sim Variant?
