APN for 4G
ehung7_
I’ve just upgraded to 4G from 3G yesterday.
APN for 3G Cellular data was ISB.MB.com and remained the same APN ISB. Should I change it to SB.MB.com?
What’s the difference between cellular data and internet tethering? The APN for internet tethering remains ISB.MB for 4G
1 REPLY 1
@ehung7_  APN will be the same regardless of the plan you have
So, is data not working for you at the moment?  If it works , leave it
Tethering is to share your mobile data to another phone/devices, is used to create hotspot
