08-31-2021 03:46 PM - edited 01-06-2022 03:19 AM
HI
Please HELP
I did an add on of 15$ for 1GB of data but I did not receive it at all.
My account is showing I have 15$ but the data is not activated
08-31-2021 10:17 PM
Because PM is Prepaid service the funds need to be in your account before you can buy an add-on. Once you add the funds you haven’t completed the purchase, you have just begun the purchase. Then select the add-on and you’re done.
AE_Collector
08-31-2021 04:12 PM
@Louloute glad it works.. yes, its a bit confusing there
08-31-2021 04:04 PM
Oh thanks soooo much
It works I could not think about this without your answer
08-31-2021 03:56 PM
@Louloute you have just loaded the fund and not really bought the Addon yet. Head back to Purchase Addon page and buy. It will use the fund currently sitting in your account for the transaction. Once done, reboot your phone and you should be good to go.
08-31-2021 03:53 PM - edited 08-31-2021 03:54 PM
sign in to Self-Serve, to review your account, if you found at Available Funds: $ ?
Try To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
after you Add-on you have to do Rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link.
08-31-2021 03:52 PM - edited 08-31-2021 03:53 PM
Purchasing an add-on is a two step process. You will need to add it to your account.
