3 weeks ago
I’ve been with public mobile for several months, the email which I registered with have been compromised and I no longer have access to it. I cannot login and when I try with my phone number it say it’s not associated. I’m looking to gain access to ultimately update my Information
3 weeks ago
just want you to be aware, the email you used to login to Public Mobile is just a login, you can still use it to login Public Mobile even you lost access to your email mailbox. it will work as long as you can receive 2FA text on your phone. So, if you have not tried it yet, try to login using the same email address and password
if you can login, all you need to do to change the login email address is to go to Profile-> Mange EverSafe ID and then update the email address (or on the app, go to Account-> Manage Login Powered by EverSafe)
3 weeks ago
@Gw7 wrote:I’ve been with public mobile for several months, the email which I registered with have been compromised and I no longer have access to it. I cannot login and when I try with my phone number it say it’s not associated. I’m looking to gain access to ultimately update my Information
You can reach a CS Agent this way and ask your email be changed.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact customer service.
