A payment was taken out that was not part of my monthly plan
wobbieca
A separate payment was taken out of my account I want to know why. My account doesn't show it anywhere. But $9.47 was taken out for some reason. Please tell me why.
self solution removed
maximum_gato
@wobbieca
Thanks for the correction on the amount. How much is your plan normally? $15 - $6 (rewards)=$9? Are there any other accounts you pay for? And there is nothing in your payment history showing that amount? If nothing else adds up then contact customer support as instructed by @hTideGnow .
wobbieca
Yes it came out of my Bank Account. My province is AB. This is what is stated on my bank account                   PUBLIC MOBILE _V  9.45. Withdrawn on April 11 2023. I checked and my March amount came out as normal. and my next due date is April 16 2023. So I have no clue what this amount is from..Never mind I realized where it was from all is ok. I really appreciate your quick reply in this have a good day.
maximum_gato
@wobbieca
From your bank account? Does it say public mobile? What province is your phone number? The amount doesn't add up to a public mobile charge with tax. The best I can come up with would be an amount with gst only. (Alberta) $9.02+$0.45 gst=$9.47 or possibly $8.26+$1.2075 (14.75% tax)=$9.47 (Quebec) Neither amount equates to a price charged by pm. Check for other possible sources of the charge? Unless your plan is a legacy $41.25 plan?
wobbieca
I will try that Thank You
Hi @wobbieca how much is that amount?
login to My account first and check Payment history and see if it shows suxh charge first
if it is not there or in doubt, submit ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
