12-04-2019 11:16 PM - edited 01-05-2022 09:55 AM
I am on a $10 plan (limit to 50 text). I need to use more text this month. Can I use the $8 US Roaming - Unlimited text add-ons in Canada? Any suggestion? Thanks.
12-05-2019 12:55 AM
@SWND You can download an app such as "TextNow". You can send text or even call any number to North America for free.
12-04-2019 11:46 PM
@SWND wrote:I am on a $10 plan (limit to 50 text). I need to use more text this month. Can I use the $8 US Roaming - Unlimited text add-ons in Canada? Any suggestion? Thanks.
@SWND...If you have access to reliable wifi...consider getting a free voip app such as TextNow. It's free and you get a Cdn phone number so you can make free calls and texts.
I'm sure there's other voip apps, but I've used TextNow and seems to work good as long as you have a robust wifi signal. Works in most Walmarts or Tim Horton coffee shops with wifi.
As the others have told you...the US Texting Add-on will only work while you're in US.
12-04-2019 11:24 PM - edited 12-04-2019 11:26 PM
@SWND You might want to consider moving up to the $15 plan the extra $5 every 30 days gives you unlimited incoming calls and unlimited texting. If your using AutoPay it comes out to $13 and you get 250MB of data.
12-04-2019 11:19 PM - edited 12-05-2019 12:12 AM
US roaming add-on is for sending text while your are in USA. It will not work while you are in Canada.
12-04-2019 11:18 PM
Roaming is only for use while in the states. No text add-ons. Use a wifi texting app maybe instead.
