03-14-2020 01:33 PM - edited 01-05-2022 09:55 AM
Hello,
I am wondering if a Vivo Y51 is compatible with Public Mobile.
A quick Google search indicates to me that it should but then the website (https://willmyphonework.net/) says it will absolutely not work.
Do bands work separately or in tandem?
Phones
03-14-2020 06:30 PM
@gblackma Right, I hear you.
Well I told him that PM has cheap plans and that they more/less "beat" the competition and he has decided today to give it a go and so far he is happy with it.
03-14-2020 06:23 PM - edited 03-14-2020 06:24 PM
You are right @Obice . I was only pointing this out, in case your friend was buying this particular phone to use on PM.
In addition, 😁😁even if you can't surf the net you can still text and once mobile data is enabled, send an mms text. Ie help me, I'm lost. So, in the long run, as long as your friend can call and text. Who cares if you have full data accessibility.😁😁
03-14-2020 06:15 PM
@gblackma Fair enough.
This is when you phone a friend. :smileyvery-happy: Or as a very last resort 9-1-1.
03-14-2020 06:13 PM - edited 03-14-2020 06:14 PM
@Obice the difference is that in areas where there is only 4g LTE data available, your friend will be unable to use it and have no data access.
03-14-2020 06:11 PM
@gblackma To that I ask what is the difference? Public throttles our data to 3mb up and down on LTE any way.
03-14-2020 06:11 PM
@CannonFodder I wasn't sure myself but trying is always best.
03-14-2020 06:11 PM
@CannonFodder If you looked at the link that I used, it also said 3g gsm band 1900 and I still will say that the data will only work on 3g, not 4g LTE.
03-14-2020 06:04 PM
@Obice wrote:To confirm, his calling and texting works and his data also works.
Awesome! 👍 I totally thought it wouldn't FULLY work, based on the few supported bands on that phone..... actually trying it is the best way to find out.
03-14-2020 06:02 PM
03-14-2020 02:53 PM
@CannonFodder I am not sure. He said he would try to test everything "later". I'd do it myself but I'm helping remotely, so if he's done I'm done.
If he can send texts I don't know why he can't make calls, too.
He said he was going to "use up some airtime" so I presume he will know soon enough.
03-14-2020 02:48 PM
@Obice wrote:I know it's working for him, he's able to text.
What about making & receiving calls?
03-14-2020 02:47 PM
@gblackma wrote:@Obice If that's all that is required, then he should be okay.
Do you and @sunflowershine KNOW this for a fact? I don't personally know enough about this stuff, but based on the frequencies that the phone supports, and what PM requires, it appears that on 3G that phone supports ONLY 850 Mhz..... 🤔
03-14-2020 02:43 PM
@Obice wrote:Thanks for the input, I searched all that though so I guess I just have to put the SIM in and find out.
THAT sounds like the best idea.... let us know what you find out.
03-14-2020 02:42 PM
03-14-2020 02:10 PM
@Obice If it is for talk and text, it should be fine.
03-14-2020 02:04 PM
03-14-2020 02:01 PM
This is for someone I know, it's not mine. So if it doesn't work on theirs I guess we'll have to figure out something.
Overall, he just needs the ability to talk and text.
03-14-2020 01:51 PM - edited 03-14-2020 01:55 PM
Public Mobile works on following frequencies:
- For 3G use (UMTS/HSPA): 850MHz/1900MHz bands
- For 4G/LTE use: 1700MHz/2100MHz bands
- For 4G/LTE use: 700 MHz band
Based on these specs https://en.gsm.cool/specs/vivo-y51 @Obice. The phone is 3g compatible only. So you will be able to talk and text everywhere and only use data where 3g is available. Any places with LTE only, data will be unavailable.
03-14-2020 01:50 PM
@Obice Based on VIVO Y51 spec. and what PM's network requirements listed below, it should be fine.
NETWORK
Technology | GSM / HSPA / LTE |
2G bands | GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 |
3G bands | HSDPA 850 / 900 / 2100 |
4G bands | LTE 850 / 900 / 1800 / 2100 / 2600 - Malaysia |
LTE 900 / 1800 / 2100 - Thailand, Indonesia | |
Speed | HSPA 42.2/5.76 Mbps, LTE Cat4 150/50 Mbps |
Check Your Phone's Compatibility
To test whether your phone i’s compatibility with our network and not marked as lost or stolen, click here.Public Mobile uses the following frequency bands:
- 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
- HSPA: 850 MHz, 1900 MHz (UMTS).
Please note that this information is indicative only. Your phone's compatibility with our 4G or 4G LTE networks is based on the radio frequencies of your phone. Public Mobile does not guarantee that your phone will work on our mobile network.
03-14-2020 01:49 PM
@Obice wrote:Hello,
Yes, that site shows it absolutely won't work, and based on what I see here: https://www.gsmarena.com/vivo_y51-7785.php I think it might be correct.
You can also check out this thread on the forums, and do a little comparison.... it seems like that phone has only a few bands that PM uses: https://productioncommunity.publicmobile.ca/t5/Discussions/LTE-network-fundamentals/td-p/130581/page...
03-14-2020 01:47 PM - edited 03-14-2020 01:48 PM
Hi @Obice
Which frequencies are supported?
They have versions that do and don't
You need 850 and 1900 MHz umts for talk
LTE would be 2,4,7 the more the better
