4 weeks ago
- last edited
4 weeks ago
computergeek541
I switched from another provider to Public Mobile and so far I have had a horrible experience. My old number has been inactivated and new one does not work - I cannot call, text or use the mobile data.
I have raised several tickets - none of which are being addressed properly. I get advice on using a different phone, restarting, resetting networks - none of this is working!! Are customer support agents normally extremely slow to respond? I have been more than a day without my phone!!
Moreover, my 'payments' tab shows double the amount I'm expected to pay - for zero service thus far.
Please give me honest feedback on whether to consider this a lost cause and to switch back to my old provider.
4 weeks ago
4 weeks ago
yes, I've tried on a different device, it does not work on another device as well. Its a physical Sim
4 weeks ago
the Customer Support folks look to be swamped right now ....seems like new activations are troublesome for a few people. Can you hold on a work with them to resolve the issue...I'm certain they'll help asap. Watch the Community inbox will be highlighted when they respond.
Have you tried the sim in a different cell yet ...ignore that suggestion if using an esim of course.
4 weeks ago
Look like the account not fully setup yet
Ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
