07-21-2026 03:18 PM
Hey there,
I recently changed phones and when I try to receive voicemails on my new phone it tells me that the call annot be Completed as dialed
07-21-2026 03:28 PM
hi @Benread2012
make sure you removed the old sim or disable old esim
Then Reboot your phone and click Reset network settings. The your phone should now programed with the correct voicemail access number.
but if it you still get the same error recording, you will have to program the voicemail number yourself. Go to dialer app, click Settings, look for voicemail and voicemail access number. Update it with one of the numbers on this page (pick one in your province):
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
