7723 google ping
webspy007
I had pixel 4XL and Kept getting 7723 turned off SMS MMS worked, but then the phone went to voicemail and could not receive text so spent $700.00 for pixel 7 and its back to 7723 and SMS APP has no turn off starting to think it's not worth the work to just send and receive when I do it not some background glitch
@webspy007   happy that it works.
webspy007
THANK YOU SEEMED TO WORK oops I don't know after 1/2 week trying to fix traded it in as it wasn't getting updates after 3 years at 1200 what BS I can build computers and web page but takes 1/2 day to change google settings but tyvm
dust2dust
Are you on the new/old $13 plan? Otherwise, how is this impacting you?
@webspy007
you can ignore those 7723 text.
 7723 is used by Google when Visual Voice Mail is enabled on dialer settings.   You can disable Visual Voice Mail from the dialer setting and the sms to 7723 will stop
What have you done instead and now all calls go to voicemail?
