lairddoug1
  • Why can't I call 611 to put in a new card? It hangs up right away. I've also tried to reset password on my public
1 REPLY 1
@lairddoug1
there is an ongoing issue with *611
https://productioncommunity.publicmobile.ca/t5/Announcements/Update-Ongoing-Issue-611/td-p/963252
Try to call 1.855.4PUBLIC from another phone and see if it works
For My Account reset , you manage to reset it?
If you cannot self reset the password, open ticket with PM Support
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
