SF1213
Public Mobile, problem calling *611, what can I do
9 REPLIES 9
SF1213
need help to reset login. submitted, waiting for reply
SF1213
submitted. thanks
waiting for reply
J_PM
Public Mobile
Public Mobile
@SF1213 If you are looking to make a payment through *611 we've identified an issue impacting some customers. Log in to My Account for now. Our teams are working on a resolution. Apologies for the inconvenience.
Bonjour @Bongo
you tried 1-855-4PUBLIC (1-855-478-2542)?
Hi @SF1213
you tried to use reset password there?
if that does not work, submit ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
SF1213
not work too.
don't have My Account login
Bongo
J'ai aussi le même problème avec *611
Hi @SF1213
Please try calling 1-855-4PUBLIC for now as *611 has problem since last week
or can you login to My Account?
