04-15-2024 03:22 PM - last edited on 04-16-2024 12:32 AM by computergeek541
I see 5GB data that showed up in my account while in the Public Mobile app, but I cannot use it. It does not show up when I log into PM via a web browser... I'm on the 15$/250MB plan so perhaps this is a glitch and it showed up as an error in the app???
04-16-2024 07:27 AM - edited 04-16-2024 07:28 AM
I haven’t changed my plan since signing up in January. Turns out it was a glitch. I contacted support and they said I wasn’t eligible for the data as I was never part of the old loyalty system. The bonus data mysteriously disappeared from the PM app. Bummer.
04-15-2024 04:04 PM
You will loss the bonus data if you downgrade your plan but the $15 plan is the lowest plan. Did you downgrade from a higher plan to the $15 plan?
If not then contact an agent to correct. Click on the Chat icon and type in Submit a Ticket.
04-15-2024 03:45 PM - edited 04-15-2024 03:51 PM
did you recently down grade to a plan of lower value ? If so, your free 150 day Bonus Data has been forfeited as per the Terms of Use.
clipped from Help Files..
Will I lose my special bonus data if I switch plans?
The bonus data will remain active unless your account becomes inactive, you switch to a plan of lower value or to an incompatible plan.
04-15-2024 03:43 PM
It's saying I'm out of data after using my usual 250MB...
04-15-2024 03:37 PM - edited 04-15-2024 03:43 PM
it'll get used once your regular plan data is used. It has a 150 day lifespan though...use it or lose it.
added...log in to your account on a laptop, clear cache files, use browser FireFox or Chrome. Look to the right on Overview Page/ Add-on Useage...look to see if you can see 5GB Loyalty Bonus Data...150 Days.
