09-24-2022 02:04 PM - last edited on 09-24-2022 02:47 PM by computergeek541
Hi. What happened to the 500mb included in my ($25 1gb) plan when set up for autopay? Did this get removed? Why did I not receive notification of this if it was removed? Is there any compensation for this if it was removed?
Also these new Public Points seem terrible. Why would I pay out at ~$40 cash value one time and loss the $5 per month benefits I have? I don't think opting in is a wise choice whatsoever. Thoughts?
09-24-2022 02:47 PM
@mathieu13 wrote:I must be losing my mind or something, lol. I may have had a promotion at some point that gave me 500mb free because I swear seeing it my account at one point or another as 1gb+500mb. Thanks for your response. I don't plan on switching rewards.
It did say that before but it wasn't a promotion. With the new Self Serve site, a mistake caused incorrect plan details to be shown.
09-24-2022 02:46 PM
Solved and done @Alexandf . Why did you add this?
09-24-2022 02:41 PM
the plan 25$ now it's showing 1GB
09-24-2022 02:11 PM
Simple thought...Don't opt out of Rewards.
09-24-2022 02:10 PM
09-24-2022 02:06 PM
It used to be 500+500. Now it's just 1gb. You haven't lost anything. Are you only seeing 500mb for the counter?
Almost every regular here is still on rewards. Don't switch.
09-24-2022 02:05 PM
Hi @mathieu13 kind if no change. Now Autopay is not a requirement for the 500MB. Everyone gets it. Simpler. So, $25 is now 1GB , no need to setup Autopay
