$50 subscription plan for $45 all data upfront means?
Veni
Hi there,
I was wondering what all data upfront for the new 90 days subscription plans. Let say it's 30 Gigs. Do I get 90 Gigs for 90 days upfront or 30Gigs for 90 days?
Thanks for your help.
2 REPLIES 2
@Veni   For the $50/30GB 90 days plan with $5 saving/month, this  is what will be like
  • you will get charge the full amount $150 on day one
  • you can get the full data usage 90GB on day one for you to use within the 90 days
  • you will get your $5 off and the monthly reward for the first month couple days after your plan start
  • you will then get your second $5 off and the 2nd monthly rewards around 30 days later and the last $5 off and 3rd monthly reards around 60 days later
@Veni  It means on day 1  you get 90 GB of dat to use over your 90 day cycle
add so in theory you can use 90 Gb in the first 30days
