11-11-2020 08:26 PM - edited 01-05-2022 04:05 PM
I'm seeing 2 possible upgrades for me because I'm blowing through 5gb every month (no idea how, I think my internet must be faulty). I'm not seeing the Autopay Bonus of $2 off for the $50 plan. Is it true that the autopay reward only works on the $45 plan?
Thanks!
11-13-2020 12:18 AM
Having autopay enabled also adds 500MB to the $50 plan, for 8.5GB total per 30 days.
11-11-2020 10:50 PM
@evevvren if you like to watch videos then I would suggest moving up to the $50/8gb(48/8.5gb auto-pay) plan.
disable these settings(android) and when your account renews, observe how much data you consume in the next 30 days. then choose a plan that fits your needs
autosync
Google photos backup
Playstore auto updates
backup to Google drive off
disable "automatic system updates" in your "developer options" (to get this option, find your os "build number" located in "about phone" and keep tapping it until "developer options enabled" appears
to save data:
keep your video quality at 480p or lower
turn off autoplay videos on your social networking apps and browser
if you really need to save data. use the "data saver" option if your device has it
use "lite mode" on your browser
if you have a wifi connection at home. use it as much as possible
11-11-2020 09:30 PM
Youtube is an excellent resource to determine what eats up data on different types of phones. I have found many different ways data can be consumed and changed many settings to reduce this. Good luck! 😁
11-11-2020 08:49 PM
11-11-2020 08:43 PM
When you are already here let's figure out what could be eating your data.
Which phone do you have?
Is your WiFi assist on (boosts your weak WiFi with your data)
Can you take a look at your data app usage and see which apps are eating most, maybe you should restrict them
Do you allow auto updates on data?
Do you give your precise location?
11-11-2020 08:41 PM - edited 11-11-2020 08:42 PM
The bonus refers to the 500megs of bonus data. The $2 off is called the autopay reward, not bonus! I read them pretty thoroughly!
11-11-2020 08:38 PM
Look closer at the pictures you posted
Autopsy is in the list of $45 plan, but it is in the'logo' of 50 plan, right under 50
Both have it
11-11-2020 08:32 PM
Autopay credit works on all plans, I am on $25 plan, also you need to plus tax to see you really paid.
11-11-2020 08:29 PM
@evevvren wrote:I'm seeing 2 possible upgrades for me because I'm blowing through 5gb every month (no idea how, I think my internet must be faulty). I'm not seeing the Autopay Bonus of $2 off for the $50 plan. Is it true that the autopay reward only works on the $45 plan?
All current price plans are elgible for a $2 autopay discount.
