07-21-2022 02:05 PM
I've change my plan to a 4g plan but I've got the same speed internet anywhere I can verify the speed of my connection. So (LTE/4G) trotled to 3 mbps same as the 3G that I got for years. The plan is change and is paid I don't need to wait to renewal date. Already try rebooting my phone verify the APN is good and what not. So anything else I'm not aware?
Plans
07-21-2022 02:11 PM
Yes I know I'm easy on it but for good measure I need to see what I paid for
07-21-2022 02:09 PM
Ok thank you
07-21-2022 02:09 PM
How long you made the change? It can take as many as 48 hours for the new speed to come.
You can try to reboot your phone ever couple hours for an update and test again
But remember, a speed test could be couple hundred Mb and can easily drain your data
07-21-2022 02:08 PM - edited 07-21-2022 02:08 PM
@pinguinz hi apparently it takes 48 hours to switch to 4g hang in there 😀
