12-01-2022 08:59 PM
I currently have the 4g LTE plan. But, when I turn on my data; it only shows 3g. How shall I proceed
12-02-2022 09:01 AM
iPhone 11 pro max
12-01-2022 10:35 PM
@0220 , what model of phone are you using? It is quite possible that your phone might have compatibility issues with 4G bands.
12-01-2022 09:23 PM - edited 12-01-2022 09:25 PM
There are some data plans that are available for existing customers right now in self service. They are 15 GB for $40 and 20 GB for $45. I am not sure how long these will be available in self service. They are under the 4G tab in plan changes. Arrow down until you see them. Choose change on next renewal date as you will not get any credit for your current plan if you decide to change.
12-01-2022 09:18 PM
@0220 wrote:I had the plan for about 5-7 months. I never really looked into it until now
If it's iPhone, set cellular data to "LTE" (4G).
12-01-2022 09:06 PM
12-01-2022 09:03 PM
If you have just switched to a 4G data plan it will take up to 48 hours for the speed to increase.
