12-27-2022 07:51 PM
I changed my plan to 4G but on my phone it still shows 3G and it’s been a couple months now will it change to 4G?
Plans
12-27-2022 08:00 PM
@SandraTuga wrote:Sometimes it shows LTE and sometimes 3G
@SandraTuga if it only shows 3G when you are on a voice call, this is normal , because PM uses only 3G for voice connection, whether you have 3G or 4G plan
What model of band of phone you have?
And, use a speed test app and tell us what speed you got from the test
12-27-2022 08:00 PM
Under your network connections, don't select automatic.
Select manual, then choose the LTE/4G option which should be listed.
12-27-2022 08:00 PM
@SandraTuga @Then you are good you will see 3G when you talk , but 4G /LTE when on the internet
12-27-2022 07:58 PM
12-27-2022 07:56 PM
@SandraTuga download speed test from app store, let us know what speed result you see
Again, LTE is 4G, so if you see LTE on top , you are good, just need a speed test to confirm the speed
12-27-2022 07:55 PM
I did all that and still the same and I changed my plan a couple months ago
12-27-2022 07:55 PM
@SandraTuga couple months, that is not normal
The 4G speed should come within 48 hours
But one thing, does it shows LTE? please be aware that LTE = 4G
Also, did you use any speed test to confirm the data speed you got?
And check your phone, see if it has set the correct Preferred network type, is it set to 3G only ? or Automatic? or something with LTE or 4G?
let us know what you see
12-27-2022 07:53 PM - edited 12-27-2022 07:55 PM
@SandraTuga change network settings from 3G to 4g also changing from 3G service to 4G can take up to 48 hours to notice difference in speed , you can try and turn air plane mode on then off might automatically go to 4g for you aswell
