10-31-2022
01:44 PM
10-31-2022
03:05 PM
computergeek541
If I switch to the 4G plan do I need to get a new SIM card to support the 4G network
Plans
10-31-2022 02:15 PM
no same sim card
you will actually be on the LTE network just throttled to what they are labelling as 4G
10-31-2022 02:01 PM
No, you do not need new SIM and all rewards and add-ons with stay on your account.
Do change plan on next renewal so you do not overpay for your service.
10-31-2022 01:45 PM
Hi @Minahil
no new sim card needed
Just change the plan using Change plan now or Change on next renewal date. The new speed will come within 48 hours of the plan change
10-31-2022 01:45 PM
