4G Switch - free data addons
esaad86
Will the free data addons from previous promos also run at 4g?
Kristowhy
@Dunkman wrote:
@esaad86
Good question.
If your base plan has LTE data, the add ons should also be LTE.
 If your base plan has 3G data, the add ons will be 3G.
This is exactly how it works with Koodo prepaid.  I imagine it's the same here on PM.
Dunkman
@esaad86
Good question.
MrSpock
@esaad86 hi yes with the new plan they will also be 4g
@esaad86   you meant activation bonus data?
likely not as the terms stated that any plan change, you will loss the activation data bonus. But you can open ticket with PM Support to confirm
