4G LTE
Jared3
How is your 4G Plan right now where i live for the 4G Rual Out Area 140 to 250 Download 20Upload or 50Upload
Jared3
i'm ew here i'm happy with my 4g
Timer
@Jared3
Plans with 3G speed may reach download speeds of up to 3 Mbps, and plans with 4G speed may reach download speeds up to 100 Mbps, with the coverage and reliability of the LTE network. Speed and signal strength may vary with your device, configuration, Internet traffic, environmental conditions, applicable network management and other factors.
check this out  coverage for 3G / 4G.
So, you are currently on a 4G plan and just asked how other's speed are @Jared3 ?
Or, did you just switch from a 3G to 4G and not experiencing different speeds yet? If so, when this change is made it should take 48 hours for the 4G to take effect.
Or, you are on the 4G and not happy with the speeds?
If so, try restarting your phone and see if that helps.
