404 error code
Jaxon20211
Hey everyone:
my wife and I came back to public mobile and she can’t get confirmation codes from the system does anyone know if the system is down
Jaxon20211
Hello just a quick question because my account is not working 100% either could I buy a hard sim and have my account info transferred onto a hard Sim????
Publicrocks501
Welcome back to Public Mobile
@Jaxon20211
came back as in new activation? or just having login long time and need to login and got the problem?
if you click Resend Code, is Send email an option there?
@Jaxon20211  Try tapping resend code a few times you should get option to send code to email instead . If no luck please submit ticket with support to help you re-gain access to it .
message support directly
while your already here and logged in the community you can send a message private message   To CS_Agents click
