12-09-2022 09:31 PM
Are the rewards for $40/15GB plan the same as $40/5GB Plan? Do my rewards come with me if I switch to $40/15GB Plan?
Rewards
12-10-2022 04:14 PM
@Coverhiro wrote:Generally rewards stay with the account, so if the account doesn't changes it's activated status then it should remain. Also depending on the new reward system or the old could mean a difference. I believe the new rewards system is a percentage of the monthly or 90 day plan cycle amount.
Rewards always stay after a plan change, not just generally. Things such as promotional discounts and free add-ons aren't part of the rewards or points programs.
12-10-2022 07:59 AM
12-09-2022 10:14 PM
@wolverine4099 , make sure not to ever switch to the point reward program. The button to switch is too conveniently located.
12-09-2022 09:33 PM
changing plan won't affect rewards at all. So, no worry. You get to keep the same rewards for any plan your change to
12-09-2022 09:32 PM - edited 12-09-2022 09:34 PM
Yes , because your rewards are attached to your account and not your plan.
