08-30-2019 07:45 PM - edited 01-05-2022 08:44 AM
08-30-2019 07:49 PM - edited 08-30-2019 07:49 PM
@RODNEY2008 hi when you set up your plan you would have set up a pin if you cant remember it you will need to contact a moderator here
08-30-2019 07:48 PM
You should have set it up when you first activated your account. Check your phone text messages. It should have been sent to your phone when you first activated. If you forgot and unable to find the text, you will need to contact moderator.
