3g phone
10-14-2020 08:00 AM - edited 01-05-2022 03:44 PM
Hi I'm on the way to get a new cheap cell phone for my husband. He does not text or go on line only wants it for calling. Will a 3g phone with public mobile?
Phones
10-14-2020 08:50 AM - edited 10-14-2020 08:12 PM
@maxwell14 wrote:Hi I'm on the way to get a new cheap cell phone for my husband. He does not text or go on line only wants it for calling. Will a 3g phone with public mobile?
3g is actually a requirement for your phone calls Since you won't be using text mesaging or data, LTE won't be used for your normal uaage. However a phone that can't connect to Public's Mobile's LTE will not be able to receive emergency alerts through the official system.
10-14-2020 08:18 AM
PM uses Telus and Bell towers which are 4G but throttles speeds to 3G. Most phones should be 3G/4G capable but make sure it is unlocked. You can also check willmyphonework.net.
10-14-2020 08:07 AM
Yes, a 3 G phone would work but it need the necessary 3G bands. Which model of phone?
Public Mobile uses the following frequency bands:
- 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS). band 12, band 5, band 2, band 1, band 4
- HSPA: 850 MHz, 1900 MHz (UMTS). - 3G bands
You can check the phone compatitibilty checker on PM website
