3GNetwork
KJ3085
I got the same message. Simple google says my phone A20 is voLTE compatible so I just moved to 5G plan. I am just hoping it will work.
@KJ3085
honest, I do not think the phone is on the whitelist, and it is probably too old to be on the whitelist.  But, you are very likely need to buy a newer, Canadian model phone like Samsung A15, A35 or newer
but you can confirm that with support by opening ticket
KJ3085
My mobile voice network type under SIM card status moves to UMTS during the call even though signal is showing 4G. Does that mean my phone is not compatible ?
@KJ3085
From what I understand Samsung A20 is not on PM's VoLTE whitelist.
However, if you see LTE when making calls, then it is using VoLTE and you might be ok.   I suggest you to open a ticket with PM CS agent to clarify.   Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Ticket", click "Contact Us"  then choose a topic, click "Login", finally click "Click here to submit a ticket ↗
    (if unable to receive 2FA via SMS when login, click "Didn't Receive code" or "Resend Code"
                then choose "
Send email" or "Send Voice Message" to get 2FA via email or voicemail)
And remember to come back and let us know what the agent says
KJ3085
My phone already showing 4G or LTE when making calls or when WIFI is not enabled. So it is VoLTE compatible. I feel like public mobile IMEI database is not up to date.
@KJ3085
To be sure if your Samsung A20 is VoLTE compatible and is on the PM whitelist of approved devices. Enter the IMEI of your A20. Here is more information:
https://www.publicmobile.ca/en/get-help/articles/volte
umnikke8
Changing plans won't have any effect, you need a phone that is on Public's compatible list.
