3G charge
poserus
I received a text say that due to #G usage I was getting a fee increase. Using your tool I checked my IME and the results said that my phone is VoLTE compatible and has 5G speed.
So why the increase?
2 REPLIES 2
FredGourdeau
I had the same issue. In my case, part of the responsability was mine: I had not correctly configured my esim and my phone was still using the 3G network when available. Other than than, contacting the cs-agent worked.
@poserus what phone is that?
If PM's IMEI checker confirmed it is VoLTE compatible, then you won't got charged the extra $5
But you can reach out Public Mobile support to clarify your current phone with them
  Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Ticket", click "Contact Us"  then choose a topic, click "Login", finally click "Click here to submit a ticket ↗
    (if unable to receive 2FA via SMS when login, click "Didn't Receive code" or "Resend Code")
     then choose "
Send email" or "Send Voice Message" to get 2FA via email or voicemail)
